1996 Daewoo Cielo ignition
90,000 MILES • 4 CYL • 2WD • MANUAL
ARMAND2010
The engine was overhauled changing half engine but after assembled its cranking but won't start. I found out there's no electrical current in the spark plug high tension wire. I change the whole distributor assy. and the ignition coil is new and both the connectors was tested and it is good but it failed to spark.
I think this model the sensor is in the camshaft inside the distributor assy. And it was already changed, but still no ignition spark.
Is the ECU has something to do with this? please I badly need help.
Thanks ,
Armando
Jun 5, 2010 at 10:56 PM
  • 55,688 POSTS
Hey ARMAND,
Use a test light and with the key on check to see if the there is 12 volts and the positive side of the ignition coil. Here is a guide to help you.
Please let us know happens so it will help others.
Best, Ken
Feb 21, 2017 at 7:08 AM
  • 55,688 POSTS
Hey,
Did you ever get the problem fixed?
Best, Ken
