Cuts out while driving
130,243 MILES • 1.4L • 4 CYL • 2WD • MANUAL
EMILE MANUEL NORAMBUENA
Hi there, my car keeps cutting out randomly, sometimes after about half an hour, sometimes less and every now and then after about 45 minutes. it starts up again if I let it rest for about 20 minutes. It also starts when i spray lubricant or carburetor cleaner on the wires that enter the distributor. I have replaced the distributor and the ignition coil but the problem persists. Any input would be greatly appreciated.
Nov 26, 2019 at 1:46 AM
  • 55,676 POSTS
When the engine stalls can you turn the key off that back on again to see if you hear the fuel pump running in the tank for about 5 seconds?
Please check out this guide to yelp us fix the problem:
Nov 27, 2019 at 6:54 AM
