Cuts out
125,000 MILES • 5.2L • V8 • 4WD • MANUAL
TIREGUY79
  • 35 POSTS
When driving at any speed sometimes it cuts out out really fast, it does not die, but it will do it a couple of times in a row or sometimes few time in a row. I have also notice it is starting to do it when taking of from a stop it almost sounds like a chirp noise or a light squeal. it is not the belt, but other then that it runs great and no lights on in the dash.
Apr 13, 2016 at 6:14 AM
HMAC300
  • 48,601 POSTS
check belt for wear recommended replacement is 60,000 for belt and tensioner. try cleaning throttle plate on both sides and iac hole.
Apr 16, 2016 at 5:29 AM
TIREGUY79
  • 35 POSTS
Ok what is iac whole and also today I drive it long distance and it started doing it pretty bad like a old car that shakes when you get in the power it idles fine and starts to ping when it acts up like it lugs out real bad do you think it's same symptoms as I described before
Apr 16, 2016 at 12:59 PM
TIREGUY79
  • 35 POSTS
And also I noticed when I got the truck there was a canister on side of gender that I think is the fuel pressure valve or the evaporate canister that was unplugged but I noticed it did the same thing before I plugged it in when it acts up and you push gas peddle in it sounds like it's struggling for air like a hollow sound
Apr 16, 2016 at 1:03 PM
HMAC300
  • 48,601 POSTS
iac hole is an oblong hole normally on throttle body, you should see it when you clean the throttle plate. scan for codes and check fuel pressure auto parts rents gauge and can scan for codes.
Apr 17, 2016 at 1:33 AM
  • 55,710 POSTS
Hey TIREGUY79,
When the engine dies can you check for ignition spark? here is a guide that can help you
Also how long does it take before it restarts? It could be the crankshaft angle sensor which these engines had a problem with.
Please let me know what you find
Apr 17, 2016 at 12:03 PM
TIREGUY79
  • 35 POSTS
It never does die it pulses like losing power and pings when it acts up and trying to push gas peddle and shakes I've been told it's the o2 censor or fuel pump
Apr 17, 2016 at 12:33 PM
  • 55,710 POSTS
It really sounds like an ignition coil, have you tried a new one?
here is a video on how what you are in for
https://youtu.be/iDgXwKA-IIc
let me know what you find.
Apr 18, 2016 at 7:55 AM
TIREGUY79
  • 35 POSTS
It was cap and rotor all rusted I put new cap an rotor and wires and plugs and runs awesome
Apr 20, 2016 at 2:33 PM
TIREGUY79
  • 35 POSTS
It was the cap and roter points had rust in them so I put new cap and rotor and plugs and wires and it runs awesome
Apr 20, 2016 at 2:36 PM
  • 55,710 POSTS
Nice work, thanks for sharing with us this information will help others, please us 2CarPros.com anytime we are happy to help out.
Apr 20, 2016 at 11:58 PM
