Car cuts off after running for twenty minutes
130,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ADAM HILLER
After it cools for a while it will start and run for about twenty minutes and cuts off again.
Apr 21, 2019 at 1:00 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Based on your description, it sounds like either you have a bad crankshaft position sensor or a bad fuel pump. When it stalls, does it feel like the key was turned off or does it feel like it's running out of gas?
Take a look through this link. It discusses the symptoms of a bad crankshaft position sensor. See if it seems to mirror your issue.
Also, if it doesn't, I suggest checking fuel pressure. Here is a link that shows in general how it is done:
Let me know your thoughts. Also, let me know if the check engine light stays on when the engine is running.
I will watch for your reply.
Apr 21, 2019 at 12:32 PM
