Cost to replace wiring under the hood
105,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
EVANCONRAD91
I have 24 error codes at the moment and 90% of them I believe are as a result of wiring needing replaced under the hood that link to the computer. My question is, what the price range I can expect to pay to resolve this issue?
Jun 17, 2018 at 12:42 PM
Good morning.
If they were to repair the wiring, it would be a time and material job. What that means is that the shop would get you to authorize say five hours to start the repair. Then when they run out of time, they will get your authorization for five more hours. They will continue until they have finished the job.
This would all depend on the tech working on the car and his knowledge.
If you were to have a wire harness replaced, then you are looking at some big bucks. The harness would be around $1,000.00 or better depending on your location and around the same to replace it as well.
The repair would be around $1,000.00 or better depending on time and parts required.
Jun 17, 2018 at 6:59 PM
