Cooling problem
155,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
TAUTVYDAS JAGUCIANSKAS
  • 7 POSTS
Last time I drove my car about three to five miles from home to work, my car half-way started smoking from the engine bay. When I got to work I opened it up and I noticed some coolant had sprayed on my hoses and radiator. How can I check what's causing the issue? I am fixing it myself. Also, could the cooling issue be causing my heater to not blow hot air or is it unrelated?
Mar 18, 2019 at 4:14 AM
D6SPAN
  • 58 POSTS
HI TAUTVYDAS,
Sounds like you have a coolant leak! The easiest way to test it is to use a coolant system pressure tester. Parts houses like AutoZone and O'Reilly have ones that you can borrow and use in their parking lot with the help of an employee or you can rent the tool from them and use it where ever you car is, which is convenient because you want the engine temperature to be cold when testing. The leak will appear when pressure is added to the system.
The heater not working could be related, especially if you are losing coolant.
I have put links to two very helpful articles. The first is How To Pressure Test Your Radiator but it involves the entire cooling system.
The second is How To Fix A Heater. It will provide you with helpful steps to figure out what the problem with your heater is.
Best of luck!
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/car-heater-not-working
Mar 18, 2019 at 4:52 AM
  • 7 POSTS
I don't know if any of my shops near by have any pressure testers for rent (forgot to mention that I'm not in the US), is there any other method to check for cracks? Or should I just replace the radiator and hoses for now?
Mar 19, 2019 at 12:24 AM
  • 55,743 POSTS
You can fill the cooling system and then install the radiator cap, start the engine and let it run, as pressure builds look for the leak using a flashlight.
This guide can help:
https://www.2carpros.com/articles/car-is-leaking-coolant
Mar 21, 2019 at 5:16 AM
