Coolant system containing thick substance
80,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BRYCE CLINE
  • 32 POSTS
I am swapping motors from a 2006 Mazda 3i and putting it in 2007 Mazda 3i both automatic. the 2007 I just bought had a serious overheating issue and toasted the motor. I was tossing the radiator etc, all of the coolant system so there isn't the question or chance of overheating it again. I want to re use the heater core but when I pulled radiator out a thick chalky liquid slowly came out. I didn't know if that would be cancer to the whole system or if I could flush the heater core and reuse the one that was part of that system?
Apr 13, 2020 at 3:57 AM
  • 110,248 POSTS
Based on what you described, I have a feeling someone was putting a stop leak product into the system. If it was me, I wouldn't use any of the original parts just because it could lead to new problems. Since the vehicle will already be taken apart, I would do it now. Also, inspect the heater hoses as well if you plan to reuse them.
I don't know if you need it, but here is a link that you may find helpful. It discusses in general how to replace a heater core.
https://www.2carpros.com/articles/replace-heater-core
Take care and good luck. let me know if you need anything.
Apr 13, 2020 at 9:53 AM
