Coolant inside the engine oil
137,000 MILES • V8 • 2WD • AUTOMATIC
TYBIZZ
I accidentally put a little bit of anti freeze in the engine oil cap.
Oct 12, 2019 at 4:30 AM
BMDOUBLE
  • 1,139 POSTS
I would let the car sit for 24 hours, then drain the oil and change the filter, pretty much an oil change service. By letting it sit without running the engine you’re allowing the coolant to settle in the pan without churning it into a foam and making it harder to get it all out. There may be other ways to go about it but this is how I would do it. Hope this helps!
Oct 12, 2019 at 5:42 AM
TYBIZZ
Thanks.
Oct 12, 2019 at 6:12 AM
BMDOUBLE
  • 1,139 POSTS
You're welcome!
Oct 12, 2019 at 6:01 PM
