Which Coolant/Antifreeze for this vehicle?
61,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
AZDANNO04
  • 377 POSTS
What coolant/antifreeze?
Jul 20, 2024 at 3:05 AM
  • 55,691 POSTS
Here are the steps to ensure proper coolant/antifreeze usage:
Coolant Type: Use a green ethylene glycol-based coolant.
Mix Ratio: Mix the coolant with distilled water in a 50:50 ratio for most climates. In extremely cold climates, a 60:40 ratio (coolant to water) can be used for additional freeze protection.
Capacity: Check your owner's manual for the exact cooling system capacity, but it's generally around 12-16 quarts for these vehicles.
Jul 20, 2024 at 4:11 AM
