Conversion to a 4 wheel drive truck
125,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
CJRUNDEZSTREETS
I realize this would be an extremely pricey task. But what are the parts I'd need to buy and install to my 2 wheel drive truck to make it 4 wheel drive. Would it be as simple as taking out certain 2 wheel drive parts and replacing them with 4 wheel drive parts?
Please list an approximate price for each item.
I have a 2008 GMC Sierra 1500 SLE 2wd : 5.3L V8
Dec 2, 2013 at 9:04 AM
  • 110,251 POSTS
To the best of my knowledge, it can't be done to your vehicle. I believe the frame is different between the two types. IF it could be done, it would cost thousands. You would basically need a new front end, transfer case, all steering components, you wound have to purchase an axle and differential for the front, the computer in your truck wouldn't work, the transmission would either need modified or replaced...
The list goes on and on and on. You would save a ton of money just getting one that is 4wd.
Dec 2, 2013 at 9:34 AM
