Compression
2000 TOYOTA TACOMA
200,000 MILES • 2.7L • 4 CYL • MANUAL
MARK MADDUX
Three of my cylinders tested at 150 lbs comp but one of them tested at 90 lbs. just wondering why such a big difference?
Mar 21, 2018 at 3:33 PM
KHLOW2008
  • CERTIFIED EXPERT
  • 41,814 POSTS
It could be due to dry or worn piston rings, leaking valves or head gasket. Give it a wet test and if the compression increases, that would be a fault of the piston rings.
Mar 24, 2018 at 8:27 AM
