Cold start misfires bank one only
56,000 MILES • 3.6L • 6 CYL • 2WD • MANUAL
ROCKW5364
Every 3-5 cold start, check engine light comes on, always p0300-301-303 sometimes 302 also. but always bank one.
new throttle body, plugs, coils, VVT solenoids, camshaft position sensor, MAF sen. All four O2's. No one in Atlanta can fix this car including the dealer. What to do?
Oct 7, 2019 at 5:22 AM
  • 110,248 POSTS
Welcome to 2CarPros.
The P0300 is a random misfire and could come from either bank. The vehicle has low mileage, but has anyone checked fuel pressure? Has anyone checked engine compression specific to those cylinders? Fuel pressure that is too high or low can cause a random misfire or even to the cylinders you mentioned. Also, there could be a head gasket issue causing lower compression in those cylinders.
Once the vehicle is up and running, does the misfire go away or do you continue to feel it?
Oct 7, 2019 at 11:16 AM
ROCKW5364
Once the car warms up, drives amazing, when at idle after driving, you can feel it stumble a little but not bad.
At first when I take off after warming up, throttle response seems a bit slow but again not bad.
Oct 7, 2019 at 9:35 PM
  • 110,248 POSTS
Welcome back:
You know, I question a couple things, but I have no idea what they have already done. Has anyone checked fuel pressure? Also, has the vehicle been checked for simple engine vacuum leaks?
Take a look through the following. When you have a misfire related to one bank (which is questionable when you have a p0300) here is a list of possible causes.
- Electric fault or loose contact in the control line to solenoid valve of camshaft adjustment
- Solenoid valve of camshaft adjustment electrically/mechanically faulty or clogged
- Hall sender rotor (sensor wheel) faulty/kinked
- Secondary air
- Intake camshaft adjustment too slow
- Intake camshaft timing incorrect
- Exhaust camshaft timing incorrect
- Fault in the valve lift control
- Oxygen sensor faulty (also: loose contact in wiring harness)
- Exhaust system blocked/narrowed
- Foreign bodies in intake tract, this can lead to sporadic misfires on changing cylinders.
_____________________________________
Are the codes you listed originally the only ones that were ever set? Also, and don't laugh, are you using premium fuel? Low octane (below 91) will cause driveability issues and misfires on this vehicle. It's just a thought.
Oct 8, 2019 at 11:14 AM
ROCKW5364
Since the misfire condition presented itself here is what has been replaced:
*Spark plugs
*Ignition coils
*Camshaft position sensor
*Mass air flow sensor
*All 4 oxygen sensors
*Throttle body
*Air filter
*Battery
I have been driving the car this week regularly and have not reset the check engine light at all since the 4 oxygen sensors where replaced. Today I scanned just to see if any changes.
Today Only p0301 was there no others?
Oct 8, 2019 at 9:51 PM
  • 110,248 POSTS
Welcome back:
Did you feel a misfire when driving? Also, clear that code and see if the same code comes again.
Oct 10, 2019 at 11:07 AM
ROCKW5364
I have never felt the misfire when driving, occasionally at idle it seems a bit rough but never bad. Wednesday night when I started the car to go home, the light was out on its own, surprise. Drove all day Thursday and Thursday night, no problem. Friday morning (cold) light came on right after I started it. P0300, 301, 302, 303, 306 Again.
Oct 10, 2019 at 11:18 PM
  • 110,248 POSTS
Based on what you said, I would recommend checking two things. First, when the engine is cold, steel contracts. If there is going to be a vacuum leak, that's when it would happen. I would check for a leak.
Next, the engine coolant temperature sensor for the computer indicates the coolant temp. If it isn't sending a correct signal, the fuel mixture could be too rich or too lean. That can cause a misfire. Interestingly, if the sensor is wrong, as long as it sends a signal, the computer has no idea it's wrong. You could check what it is reading with a live data scanner if you have one. Just check what it indicates the temp is when the engine is cold and hasn't been run. Does the temperature seem to mirror what the ambient temperature is?
Here is a link that shows how to find a vacuum leak:
I suspect they are missing something simple. To have it run properly and then have that many misfires is most likely a simple fix. (at least we would hope.)
By the way. If you have a live data scanner, can you provide the short and long term fuel trims when the engine is at an idle? It may help me figure things out easier.
Let me know what you find.
Oct 11, 2019 at 1:48 PM
