Codes P200A, that come up when scanner is plugged in?
2011 KIA SORENTO
178,546 MILES • 4WD • AUTOMATIC
KENZIELAMPMAN
P200A
$7E9 A/T
Aug 26, 2023 at 1:43 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
The P200A code for a 2011 Kia Sorento generally pertains to the Variable Valve Timing (VVT) system of the engine. Specifically, it usually indicates a problem related to the intake manifold runner control or its performance. This is an essential part of the engine management system that controls the flow of air into the intake manifold, thereby optimizing engine performance in real-time based on driving conditions.
The "$7E9 A/T" refers to one of the on-board computer systems that the OBD-II (On-Board Diagnostics, version II) tool is able to communicate with. "$7E9 A/T" is typically related to the transmission control module.
Common Causes of P200A:
Faulty Intake Manifold Runner Control (IMRC) Valve or Solenoid
Wiring harness issues or poor electrical connections
Carbon build-up on intake manifold or valves
Software issues in the Engine Control Module (ECM)
Mechanical issues within the intake manifold
Troubleshooting Steps:
Scan Tool Diagnostics: Use an OBD-II scanner to read any other codes that may be stored in the ECM. These additional codes could provide more information about the underlying issue.
Inspect Electrical Connections: Check the wiring and connectors related to the IMRC and clean or repair as necessary.
Check the IMRC Valve: The IMRC valve can sometimes fail or stick. Some testing may be required to determine if it is functioning correctly.
Carbon Cleaning: Carbon deposits can interfere with the IMRC's ability to control air flow properly. A cleaning procedure may resolve the issue.
Check for Updates: Occasionally, a software update from the manufacturer may be required to resolve this issue.
Clear Codes and Test Drive: After the repair, clear the code with an OBD-II scanner and perform a test drive to ensure that the issue has been resolved.
Please go over these guides and get back to us.
Aug 26, 2023 at 1:33 PM
