Codes p025c, p300, p301, p302, and b210068, misfires?
2014 MERCEDES BENZ C250
145,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Has codes:
p025c
p300
p301
p302
b210068
I am leaning toward a fuel problem.
Apr 30, 2023 at 6:05 AM
  • 55,381 POSTS
Here is what is said about the codes:
P025C: This code refers to an issue with the fuel pump module communication circuit.
P0300: This code is a general misfire code, which means that one or more cylinders in the engine are not firing correctly.
P0301: This code specifically indicates a misfire in cylinder 1.
P0302: This code specifically indicates a misfire in cylinder 2.
B210068: This is not an OBD-II error code and I could not find any information on it. Can you please confirm the accuracy of this code?
So, it looks like you may have a fuel pump going out and a fouled or worn spark plug. How does the engine run? Can you upload a video of the problem?
May 1, 2023 at 2:11 AM
