rough idle on cold start, codes with multiple codes?
169,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
A bit of rough idle on cold start, codes
110001
190302
191c02
Cd9435
118402
11a031
Mar 19, 2023 at 5:33 AM
  • 55,721 POSTS
110001: This code indicates a fault in the fuel pressure sensor circuit.
190302: This code indicates a fault in the crankcase ventilation system.
191c02: This code indicates a fault in the throttle valve actuator.
Cd9435: This code indicates a fault in the coolant pump.
118402: This code indicates a fault in the intake air temperature sensor circuit.
11a031: This code indicates a fault in the mass air flow sensor circuit.
Mar 19, 2023 at 11:38 AM
