I just bought a 1997 Saturn 4dr SDN 1.9 liter. The car was sitting for a couple years. When I started it up, it shook real bad, and when you first pull off, it acts like it has no power until it gets going, then it is ok. It does not shut off during idle. The code reads a misfire. I checked the plugs in which they look to be a burnt build up on the tips. I bought new plugs and wires. However, I have no way of making sure that the wires are currently in the right order from the coil to the plug. I am going to change them one at a time putting the wires back in it's current position. How can I be sure that they are in the right position without a photo, and will changing the plugs and wires resolve the problem?
Dec 23, 2015 at 2:50 PM
