Clutch started slipping and then stopped slipping
285,000 MILES
SATURN MAN
The clutch began to slip and seemed to be getting worse over time. So I parked it and after letting it sit for about six weeks or so I took it for a spin and the clutch is not slipping anymore. I accelerated pretty hard in 5th gear and it did not slip at all. Could something besides wear have caused it to start slipping in the first place? If it is in fact worn out is there any reason why it would stop slipping after sitting for several weeks? I've never had a worn out clutch stop slipping for any reason. What do you think? Thanks very much.
Frank
Aug 26, 2013 at 6:50 AM
SATURNTECH9
  • 30,869 POSTS
I have never really seen a clutch stop slipping by itself ether.What I have seen is the fingers in the pressure plate wear unevenly or half of them will be lower then the other half.Causing partial clutch disc engagement so only half of the clutch disc is engaged or disengaged.
Aug 26, 2013 at 6:59 AM
