Clutch problem?
130,000 MILES • 1.7L • 4 CYL • 2WD • MANUAL
CHRISJD76
Low gears and reverse are very stiff to select when the engine is cold. This improves after the car is up to running temp but does not completely resolve it. No obvious fluid leaks. Gear change is smooth in higher gears and clutch biting point has not changed. I was told when I bought the car that the clutch was replaced at 90,000 but I have no paperwork for this. Any advice on what could be wrong would be gratefully received.
Dec 11, 2022 at 8:54 PM
  • 55,561 POSTS
It sounds like the clutch is starting to come apart and not release fully. To be sure here is a guide and a video to help confirm the issue:
https://youtu.be/EpBMj5ZY_bo
and
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Please go over these guides and report back.
Dec 12, 2022 at 3:00 AM
