Clutch/pressure plate
2011 HYUNDAI GENESIS
90,000 MILES • 3.8L • V6 • 2WD • MANUAL
WESTLEY BRENT STONE
I have the car listed above r-spec six speed. My car is having problems going into gear when rpm's are over approximately 3000. it will not downshift unless the gear it is going into when clutch is released is below approximately 3000 rpm's. Any help would be greatly appreciated. I am wanting to say the pressure plate is wore down but do not want to make any assumptions and want to get someone else's opinion who knows what the deal is or maybe has experienced before. Please help!
Mar 15, 2018 at 2:09 PM
  • CERTIFIED EXPERT
  • 31,937 POSTS
May be a syncro problem in the gear box. try changing the oil and try a double shift to see if it will select.
Mar 15, 2018 at 8:16 PM
