Clutch pedal assembly requires excessive foot pressure needed to finally get starter to turnover
175,000 MILES
BLULIGHTNIN813
Have to push the clutch down very hard to floor to get the starter to engage and turnover. It seemed like it was excessive foot pressure needed to finally get starter to turnover then it just stopped turning over with it all the way to floor...few months ago pedal went to floor, and I reattached pedal assembly under dash and it worked fine until it won't start now.
Jul 5, 2022 at 12:24 AM
  • 55,649 POSTS
There is a clutch safety switch near the top of the clutch pedal that needs to be adjusted. Also, if you have a floor mat this can cause an issue as well.
Clutch Switch - On Clutch Pedal Bracket
Let us know what happens and please upload pictures or videos of the problem.
Jul 5, 2022 at 10:23 AM
