I need to identify the part that connects the clutch pedal in foot well?
140,000 MILES • 1.6L • 2WD • MANUAL
LARRYCAN
I need to identify the part the connects clutch pedal in foot well?
May 8, 2023 at 1:50 AM
  • 55,732 POSTS
The part that connects the clutch pedal to the master cylinder on your 2016 Nissan NV is called the clutch pedal linkage. It consists of several components including the clutch pedal, the clutch pedal arm, the pushrod, and a clevis pin that connects the pushrod to the clutch master cylinder. But I am not showing a manual transmission in this vehicle. Can you upload a picture of what you are seeing?
May 8, 2023 at 9:58 AM
