Clutch issues
2005 HYUNDAI TIBURON
65,000 MILES • 2.7L • V6 • FWD • MANUAL
JOHN PAYNE2
  • 6 POSTS
Okay, a quick overview i have replaced flywheel. Clutch disc. TOB. Slave cylinder. I have bleed the system i have took a video proving the slave pushes the arm and pulls the TOB and pulling the pressure plate a good distance out however it will not go into gear when engine running even if i use a pry bar and pull pressure plate and TOB to the max disengagement. The disc is 100% in the correct way flat to flywheel or it would have snapped is there any other reason why the clutch plate may not be disengaging.
The image shows the TOB pulling the pressure plate 100% out to the stop.
Many thanks
Jul 24, 2017 at 2:10 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
I will be happy to help you today, do not see an image?
Please get back to me, Ken
Jul 25, 2017 at 1:48 PM
