Clutch not working
2003 FORD F-150
120,000 MILES • 6 CYL • 2WD • MANUAL
ROBERT EADS2
Exiting off highway, downshifting, clutch pedal got hard instantly with no warning. Wouldn't go to the floor so I could shift. Suddenly popped loud like something broke then it went to the floor. Truck won't start without clutch pushed in, but it starts now but won't go into gear.
Sep 4, 2019 at 12:29 PM
Good evening.
Sounds like the throw-out bearing in the clutch failed and damaged the pressure plate. Look like you will need to replace the clutch assembly.
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
https://www.2carpros.com/articles/how-to-replace-a-clutch
Mar 24, 2021 at 4:20 AM
ROBERT EADS2
I was hoping it was just the linkage, but you're the second person to bring up the throw-out bearing. I can't even crawl under it to check anything until I can get jack stands over there this afternoon. Thanks.
Robert
You are welcome.
Keep us updated.
