Clutch bleeding
120,000 MILES • 1.3L • 4 CYL • TURBO • 2WD • MANUAL
PHILWOOD
I have fitted a new dual mass and 3 piece clutch kit, converted the old CSC pipe to the new supplied push fit plastic connector. I have been bleeding the clutch all day but it's not getting any better, the clutch pedal is biting right at the top and feels like it will slip under load. I can engage all gears no problem the clutch just doesn't feel like it's releasing in gear. is there an easy way to bleed the clutch system or something wrong? thanks, Phil
Jun 22, 2020 at 5:41 AM
  • 110,248 POSTS
This vehicle isn't offered in the US, so I have no technical info specific to the vehicle. However, I will try to help.
I need to know what all was replaced. Was it the clutch and pressure ?
Jun 23, 2020 at 12:10 PM
PHILWOOD
Yes new dual mass flywheel, new clutch plate new pressure plate and new concentric slave cylinder.
Jun 23, 2020 at 4:53 PM
  • 110,248 POSTS
Are you able to access the bleeder? Have you tried gravity bleeding it? When you gravity bleed it, make sure the clutch pedal is fully at the top of its travel.
Let me know what you have done already to bleed the system. To be honest, if there is air in the system, I would be expecting the opposite to happen, spongy pedal, not wanting to disengage the transmission/engine. The idea that it grabs when the pedal is near the top doesn't make sense to me unless something wasn't installed correctly. What makes it worse for me is I have no technical info on this vehicle, so I can study the system to determine what could cause it.
Jun 24, 2020 at 1:31 PM
