Push in the clutch the car will shut off
100,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
EAGLE TALON
  • 6 POSTS
Recently I've noticed when I push in the clutch the car will shut off. It is random most the time, other times its reoccurring. It is a 420a. all sensors have been replaced as far as the MAP, crank, cam, throttle body position, idle air control valve. I'm stumped. No codes either.
Feb 10, 2019 at 6:19 AM
  • 110,248 POSTS
Since you replaced the aforementioned components, my first suspect is an engine vacuum leak. Here is a link that shows how that is done:
Start with that and let me know the results.
Feb 10, 2019 at 1:16 PM
EAGLE TALON
  • 6 POSTS
Okay, I'll give it a look. I've also replaced the PCV valve, and I've replaced all of the valve cover vacuum lines. Also you think it could possibly be a bad clutch switch? I'll keep you posted. Thank you
Feb 11, 2019 at 2:44 AM
  • 110,248 POSTS
Welcome back:
The clutch switch is only utilized for starting purpose. It won't cause a stall.
Let me know what you find.
Feb 11, 2019 at 10:46 AM
EAGLE TALON
  • 6 POSTS
So I've checked out the vacuum lines and so far everything checks out. But there is something else I found. There was a small clamp on the fuel line right before the fuel rail. Does the stock 420a for the 1995 Eagle Talon come with a fuel pressure regulator? I'm going to get a pressure gauge for the fuel rail and see what its putting out.
Feb 11, 2019 at 11:14 AM
  • 110,248 POSTS
Welcome back:
Yes it does have one. It should be on the fuel rail and have a vacuum hose going to it. Here is a link that shows in general how to check pressure and the regulator:
Let me know if this helps.
Feb 11, 2019 at 11:44 AM
