Transmission will not shift into gear
130,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
HOBBS1
Won't go into gear, checked clutch cable seemed to be in good working order. What else could it be? Is there such a thing as a clutch post? And how much will it cost me to fix it myself and shop price too?
Jun 18, 2022 at 3:17 AM
  • 110,248 POSTS
Does this have an automatic or manual transmission? I ask because the manual transmission clutch is operated hydraulically. I'm not sure what cable you are referring to. Also, you indicated it's an automatic above.
Let me know. If it is a manual transmission, with the engine off can you shift through the gears? If so, then it is likely either the clutch master cylinder or the slave cylinder.
Let me know so I know which way to point you.
Jun 19, 2022 at 1:35 PM
