Cluster dash fluctuating gauges
300,000 MILES
BILL MELNICK
All the dashboard gauges are fluctuating.
Aug 8, 2020 at 11:57 AM
  • 110,248 POSTS
Are they moving in sync at the same time? Can you video what is happening and upload it for me to see?
Aug 8, 2020 at 2:02 PM
BILL MELNICK
Yes they are? I have looked on YouTube the cluster panel board has cracked soldering.
Aug 8, 2020 at 2:08 PM
STEVE W.
  • 15,410 POSTS
Cracked solder is getting to be a common issue with vehicles ever since they stopped adding lead to the solder. Now instead of having flex it is brittle and fails. Happens with clusters, ECM's, and most other modules as well. However repairing them can be interesting if you don't have the proper equipment to solder surface mount components at it is very easy to overheat the solder pads and burn them off of the board. If parts are damaged they can be very difficult to find replacements for as well. However, if you have the tools and the abilities it is possible to repair them, you are the best at determining if that is the case.
Aug 8, 2020 at 2:29 PM
