cluster compatible
100,000 MILES
MEG GUILLOT
What other cluster can I replace mine with that is compatible?
Feb 6, 2020 at 11:58 PM
STEVE W.
  • 15,409 POSTS
You need a bit more information to determine that. There are a number of different clusters depending on which option package you have, which engine and transmission, 2 or 4 wheel drive. Then the cluster needs to be programmed to match your vehicle or it will not operate correctly.
What is the issue with the cluster you have? They fail a lot but are usually repairable.
Feb 7, 2020 at 12:59 AM
