Clunking, I can hear something moving before starting the vehicle?
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
STEVIE12
  • 55 POSTS
When I sit down in truck before starting, I hear movement a clunking sound.
Jul 27, 2022 at 1:14 PM
  • 110,248 POSTS
That's an interesting one. By chance, can you tell approximately where it is coming from? For example, front, rear, left, right, inside, exterior, and so on. Also, if it is loud enough to record, could you do that and upload it for me to hear?
Jul 27, 2022 at 1:32 PM
STEVIE12
  • 55 POSTS
Front.
Jul 27, 2022 at 2:24 PM
  • 110,248 POSTS
Is there anything that seems to prompt the sound? For example, does it happen when you first turn the key to the run position? Does it happen when you close the door?
I'm sorry for so many questions, but this is a tough one without being there. Also, when you say front, is it in the vehicle, or does it seem more so under the hood or outside the vehicle? I ask because if it's outside the vehicle, it could something like an exhaust hanger that broke, and the exhaust is swinging and bumping something from the movement of you getting in the vehicle.
Let me know as much as you can.
Jul 28, 2022 at 5:35 AM
STEVIE12
  • 55 POSTS
Thanks. when I get in truck and sit I heard a clunking sound also hear off and on while driving.
Jul 28, 2022 at 7:34 PM
  • 110,248 POSTS
The first thing I would check is the exhaust system. Take and see if you can move it around by the tail pipe.
Let me know what you find.
Jul 29, 2022 at 1:21 PM
STEVIE12
  • 55 POSTS
Okay, thanks.
Jul 29, 2022 at 3:13 PM
  • 110,248 POSTS
No problem whatsoever. If you have a chance, let me know if you find the noise.
Jul 30, 2022 at 12:28 PM
STEVIE12
  • 55 POSTS
Thanks. Could it be struts, ball joints, or shocks?
Jul 30, 2022 at 2:17 PM
  • 110,248 POSTS
Anything is possible, but those things have pressure on them and simply getting into the vehicle wouldn't likely cause a noise.
I guess if you have a shock that is completely blown and the bushings mounts are bad, it could happen, but that is really unlikely.
Have you had a chance to check the exhaust? Also, have a helper get in the vehicle while you stand alongside it and see if you can hear it from the outside.
Jul 31, 2022 at 4:21 AM
STEVIE12
  • 55 POSTS
Okay, thank you.
Aug 8, 2022 at 11:42 AM
  • 110,248 POSTS
I haven't heard from you for a few days. Have you had any luck finding where the noise comes from? I'm interested in knowing.
Aug 10, 2022 at 3:09 PM
STEVIE12
  • 55 POSTS
No, I did try shaking tailpipe it secure.
Aug 10, 2022 at 8:09 PM
  • 110,248 POSTS
By any chance, is it loud enough for you to record and upload for me to hear?
let me know.
Aug 11, 2022 at 6:29 AM
