Clunk giving gas, letting off gas
140,000 MILES • 6.2L • V8 • 4WD • AUTOMATIC
BRUCEJ455
Ring and pinion have a pattern I have never seen before. Ridge of gear is tapered out to inside, same with ring. Does not have play at pinion, but howls on drive side (softly). Two questions; can transfer case give me clunking noise. Second, axles all the way in and cannot get enough space to remove clips. What gives? Thanks ahead, Bruce
Jul 17, 2018 at 5:26 AM
Good evening.
Yes, the transfer case could give you the noise.
I am more inclined to think a motor mount whether engine mounts or tansmission mount.
The bearing could have caused the ring and pinion wear. You need all the bearings plus ring and pinion.
Take a rubber mallet and smack the axle on the face to get the last little bit to get the C clip. They can be a pain.
Jul 17, 2018 at 9:25 AM
