clunk felt on my steering wheel
50,000 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
DUBAI123
Ive had this problem were when you turn left or right you get this knock or click rubber sensation through the steering wheel. I get it when you are going at speeds below 10mph with u turn and when stationary on uneven surfaces . when turn wheel on both directions .
it is present for 2 years and not changing
I took it to dealer and not recall problem in front suspension parts but the click is present
I know there is a broblem but don't know
can u help to clarify what is going on and what to do
Dec 11, 2015 at 3:32 AM
CARADIODOC
  • 34,415 POSTS
Since this appears to have been happening since the car was new, a worn part is not the likely culprit. Instead, start by looking at the steering shaft under the dash to see if there's a universal joint that is rubbing on something. Also, the clock spring can cause noises, but only if it's starting to come apart. That's a wound-up ribbon cable in a plastic housing under the steering wheel.
Also look at the two accordion boots on the rack and pinion steering gear to see if something is rubbing on one of them.
Dec 11, 2015 at 5:59 AM
