clunk clunk noise and felt like it was going to shut off
150,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
MOMMY182005
I was driving my vehicle listed above the other day and it made a clunk clunk noise and at the same time felt like the vehicle was going to cut off but didn't and slowed down at the same time. It acted like it didn't want to accelerate and the oil light came on. I managed to get to home which was right down the road not even a mile. I checked the oil since the oil light came on and it was low. I got oil and put oil in the vehicle. Drove it to see if that helped and it did it again. I noticed around about five miles it would do it.
Mar 8, 2020 at 7:55 AM
Let's start with codes.
If the oil light is coming on, that is just because the oil pressure is dropping. This could be due to exceptionally low RPM's or a greater issue.
If you can't pull codes then just run by a parts store and they should be able to pull it free of charge. I imagine we will have some codes but if not, we can do more investigation. However, if we have a code it will cut this down considerably and we can get right into testing and following the diagram for that code.
Let me know if you have questions.
Mar 8, 2020 at 8:27 AM
MOMMY182005
I took it by an auto part store and the reader came up no code.
Mar 8, 2020 at 11:03 PM
Okay. Can you get a video of what this is doing? Just get a video of the dash as you are driving and then narrate when it does the issue just in case we can't hear it. Seeing it will give us a better idea as to what the issue could be.
Mar 10, 2020 at 10:15 AM
MOMMY182005
My husband took it to a shop yesterday and we are waiting to see what they say is wrong with it.
Mar 10, 2020 at 10:16 AM
Fair enough. Please keep us updated because not only am I curious but that info will surely help others when they visit this site with the same info. Thanks for the update.
Mar 10, 2020 at 10:52 AM
