Clock spring replacement
2015 SUBARU FORESTER
60,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
SUBARUTED
After replacing the clock spring are there any codes that need to be reset?
Thanks for your help.
Mar 27, 2019 at 4:21 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Welcome to 2CarPros.
If you replace only a bad clock spring, there really shouldn't be anything that needs cleared. It should automatically turn off any lights related to the SRS system. If you had other codes not related, they may need looked at to see what caused them.
If you could, let me know what prompted you to replace it. Was it a code, was it a light. anything you can let me know will help.
Mar 27, 2019 at 8:18 PM
SUBARUTED
Thanks Joe! The horn stopped working. My garage's diagnostics led to the clock switch.
Mar 28, 2019 at 5:30 AM
  • 110,190 POSTS
That will do it. Let me know if you run into any trouble.
Mar 28, 2019 at 5:27 PM
SUBARUTED
Clock spring change went smoothly. No codes to reset. Thanks for your help Joe.
Ted
Mar 29, 2019 at 5:18 AM
  • 110,190 POSTS
You are very welcome, Ted. Let us know if you need anything in the future.
Have a good weekend.
Mar 29, 2019 at 8:53 PM
