Clicking sound from my back right wheel
280,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
MBANUGO UBA
I hear a click like sound coming from my back right wheel when I hit the brakes. it just happens once I step on the brake pedal and especially in the mornings but as soon as the car is driven for a while it stops. Also, whenever I go over a bump, even the minutest bump I hear it "click", like two metals clicking together. What could be the problem?
Apr 28, 2017 at 3:25 AM
JOHNNYT73
  • 924 POSTS
This could be a number of things rotors being warped, hardware is missing or damaged. the only thing you can do is disassemble the brakes to visually look and see what could be causing the issue.
Apr 28, 2017 at 3:51 AM
MBANUGO UBA
Thanks for the quick response. I will have my mechanic check it right away. But say the things you mentioned are bad. could they be repaired?
Apr 28, 2017 at 4:04 AM
MBANUGO UBA
Or do I have to get new parts?
Apr 28, 2017 at 4:05 AM
JOHNNYT73
  • 924 POSTS
You would have to get new parts. They should all be fairly inexpensive.
Apr 28, 2017 at 4:12 AM
MBANUGO UBA
Thank you so much. i will recommend this site to all my motor head friends. Once again thanks a lot.
Apr 28, 2017 at 4:15 AM
JOHNNYT73
  • 924 POSTS
you are very welcome and thank you for using 2carpros!
Apr 28, 2017 at 4:20 AM
