Clicking noise
185,000 MILES • 3 CYL
MIKEY22
I did a tune up and to get to the spark plugs I had to take the fuel rail off. When I took off the rail one of the injectors was stuck in the intake manifold. I took it out and saw that the plastic tip part was cracked/brittle. So I replaced and put a new injector in. I have also noticed that those where the original fuel injector to the car and no one sells the original one. So the one I got was the one for the vehicle but aftermarket. I installed and now the car is making a clicking noise and hesitates when accelerating. Please help I am stumped. I changed fuel filter, air filter
Apr 18, 2016 at 12:27 AM
  • 55,616 POSTS
Hey, yep those aftermarket injectors can play havoc on the way the engine runs, did you try fordparts.com
I found this http://www.fordparts.com/Commerce/PartDetail.aspx?n=RP0YrgFW7y7h5WEekFN3sg%3d%3d&id=346393780&m=2&search=true&year=2000&make=Mercury&model=Grand%20Marquis
let me know what happens
Apr 18, 2016 at 4:06 AM
MIKEY22
It was another injector clogged so I just got some Seafoam and cleaned the injectors. And she is back on the road
Apr 18, 2016 at 10:01 AM
  • 55,616 POSTS
Great to hear, that stuff really works! Please use 2Carpros.com anytime and tell a friend.
Apr 18, 2016 at 10:45 AM
