2004 Citroen Zara windscreen wipers
2004 CITROEN ZARA
JAYNE90
2004 Citroen Zara Two Wheel Drive Manual 41500 miles
windscreen wiper have stopped working I have checked the fuses, mechani has checked the motor which is ok, i have reset the computer, ie disconnected battery, no change. Mechanic said something about a relay switch and cears for wipers, a bit over my head can you tell me solution and how to fix it,##thanks
Jan 31, 2009 at 3:00 AM
DAVE H
  • 13,384 POSTS
replace the relay located in the fuse/relay box
Mar 12, 2010 at 10:17 PM
JAYNE90
[quote:e0a9c2b0e3="jayne90"]2004 Citroen Zara Two Wheel Drive Manual 41500 miles
windscreen wiper have stopped working I have checked the fuses, mechani has checked the motor which is ok, i have reset the computer, ie disconnected battery, no change. Mechanic said something about a relay switch and cears for wipers, a bit over my head can you tell me solution and how to fix it,##thanks[/quote:e0a9c2b0e3]
The control panel? for the lights above the steering wheel was taken off, when it was put back on the wipers worked, must have rebooted something.
Mar 13, 2010 at 3:30 AM
