1994 Citroen Zara
1994 CITROEN ZARA
80,000 MILES • 4 CYL • 2WD • MANUAL
MILLERSM
removed cylinder head and have oil sitting on top of piston head is this normal, engine was overheating.
Jun 30, 2009 at 8:07 AM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated you may have a had a bad cylinder headgasket .. this was causing the overheating and allowing oil/water into the piston chamber's .. have the head pressure tested while off the vehicle to be sure it is ok (not warped/cracked) then replace with a new gasket set !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_841.png
Jun 30, 2009 at 10:30 PM
