2002 Other Citroen Models mysery misfire
2002 CITROEN
75,000 MILES • 4 CYL • 2WD • MANUAL
NEGSY26
hi, my berlingo is misfiring on idle. when it gets some throttle it seems to be ok. the misfire is causing my emissions to be high thus causing mot failure.coil pack seems ok and a compression test has shown all is fine, any ideas?
May 1, 2009 at 7:09 AM
DAVE H
  • 13,384 POSTS
replace spark plugs, coil pack and wires .. add a good fuel cleaner to the tank to clean the injectors
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_670.png
May 7, 2009 at 12:46 AM
