2001 Other Citroen Models Springs
2001 CITROEN
GLORIA22
Suspension problem
2001 Other Citroen Models Front Wheel Drive Manual 73000 miles
My Citroen Picasso is off the road and Im not sure if I can drive it to garage!! I was about to make a long jurney on the motoway and I went to pump up the tyres on doing this I noticed under thr front wheel arch a sring was hanging down and resting on the tyre!! as a result the brang new trye has a big ridge down the centre of it. Im not sure what has happend and dont know if I should drive it and if it sounds costly. As you can probably tell Im a woman and usually end up getting ripped off as a result of not knowing wha Im being told is the truth!
Mar 1, 2009 at 7:51 AM
DAVE H
  • 13,384 POSTS
The coil spring has snapped and needs replcacing .. do NOT drive the vehicle to the garage call you breakdown cover and have it towed .. tell your garage you just want the spring and tyre replacing ..
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_242.png
Mar 14, 2009 at 11:11 PM
