2003 Citroen C5 Engine noise
2003 CITROEN C5
115,000 MILES • 4 CYL • 2WD • MANUAL
HOTPEPPER6005
My car has started making a high pitched whistling/grating noise aligned to the engine revs. As the revs go up, the noise gets louder and more pronounced. If I depress the clutch when moving, the noise immediately goes as the revs drop to 1000rpm, then starts again when the clutch is released. No other indications such as temperature, pressure showing. The only thing I can compare the noise to is something like a Scalectrix car going round the circuit. Any ideas?
Dec 1, 2009 at 8:58 AM
DAVE H
  • 13,384 POSTS
start by checking/replacing the drivebelts and tensioner are good !
Dec 30, 2009 at 9:00 PM
HOTPEPPER6005
Thanks Dave H. Turned out to be a drivewheel for the belt. All sorted now. Just need to sort out the satnav which is going!
Jan 3, 2010 at 8:28 AM
