2003 Citroen C5
2003 CITROEN C5
120,100 MILES • 4 CYL • FWD • AUTOMATIC
STAN.2MAN
CAN YOU PLEASE TALL ME WHAT IS Hydrolastic displicers are and where thay are
Thank you
stan o'Brien
Mar 25, 2009 at 9:27 AM
DAVE H
  • 13,384 POSTS
these are a part of your suspension system !!
The principle is simple. The front and rear suspension units have Hydrolastic displacers, one per side. These are interconnected by a small bore pipe. Each displacer incorporates a rubber spring (as in the Moulton rubber suspension system), and damping of the system is achieved by rubber valves. So when a front wheel is deflected, fluid is displaced to the corresponding suspension unit. That pressurises the interconnecting pipe which in turn stiffens the rear wheel damping and lowers it. The rubber springs are only slightly brought into play and the car is effectively kept level and freed from any tendency to pitch.
Aug 30, 2009 at 8:34 AM
