When engine is running the brake pedal loses pressure and goes to the floor
2003 CITROEN BERLINGO
89,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
GRIDGWAY
Brake pedal when engine isn't started has pressure. When I turn engine on the brake pedal loses pressure and goes to the floor, with basically no braking potential.
Not sure if it is brake master cylinder or booster.
Can hear air as I press brakes to floor.
No apparent leaks of brake fluid, reservoir is full.
Any suggestions?
Citroen c15
Jul 5, 2019 at 12:36 AM
  • 110,244 POSTS
Welcome to 2CarPros.
First, this vehicle isn't offered in the US so I have little technical information related to it. However, if the brake pedal is going to the floor, it is most likely the result of a faulty master cylinder. Over time, the plungers break down and allow fluid to bypass them. The level in the reservoir won't change because it isn't actually leaking. Without the power assist when engine is off, you aren't able to push it to the floor. With the assist, vacuum is doing the work and it goes to the floor. Note: With the engine off, press and hold pressure on the brake pedal. See if it slowly goes down. I bet it will.
Regardless, if there are no leaks and the reservoir is full, suspect a bad master cylinder.
Take a look through these links:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Here is a link that shows how in general one is replaced.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Jul 5, 2019 at 12:16 PM
