1999 Citroen C1 brakes
1999 CITROEN C1
70,000 MILES • 4 CYL • 2WD • MANUAL
DARRAN538
my brake lights are sticking on on my peugeot 206 1.4 what could be the cause?
how can i resolve this problem?
(i put citroen because peugeot wasnt an option)
Feb 3, 2008 at 12:10 AM
MERLIN2021
  • 17,250 POSTS
Look on the brake pedal arm, if it's like most cars, and BTW I am not a Peugeot mechanic...you will see a stop light switch, try pushing it into the bracket, until the lights go out, then pull up on the pedal. If not helpful you may need to replace the switch...
Feb 3, 2008 at 12:41 AM
