2005 Chrysler Town and Country code PO499 and PO301
2005 CHRYSLER TOWN AND COUNTRY
59,000 MILES • 6 CYL • 2WD • AUTOMATIC
DIYNOW
I have mil cyl # 1 misfire and NVLD canister vent valve soleniod circuit indicating high voltage. How do I go about correcting the problems, and can either of the malf. cause problems across systems wich lead to the service engine light to illuminate?
Oct 29, 2008 at 12:48 PM
JNOVACK
  • 723 POSTS
the egr valve should be replaced that will most likely stop the misfire and if it doesn't then I would change the spark plugs and wires
Oct 29, 2008 at 1:31 PM
BMRFIXIT
  • 19,053 POSTS
if spark checked OK and wire too
TSB ( PCM need to flashed )
check with the dealer for that services as it maybe still under warranty
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 29, 2008 at 1:46 PM
JNOVACK
  • 723 POSTS
P0499 comes up as a EGR valve malfuntion in my chrysler manuals that is why I am saying the egr valve needs replacing
Oct 29, 2008 at 2:25 PM
