2003 Chrysler Town and Country Won't go faster.
66,000 MILES • 6 CYL • FWD • AUTOMATIC
KASKA9US
I can not drive more than 40mph if road has a slop.
When I hit the gas paddel, the rpm goes up but not going faster. I went to the dealer and diag. there was no code for trans or engine but they noticed gas pump and filter need to replace and recommanded tune up, replacing spark plugs, change trans. oil.
I did that and still having issue.
If engine or transmission problem, my car could covered by power tran warranty but there was no indication through the dealer computer scanning result.
what can I do? keep fixing other parts will causing a lot of money. Anyone have idea what might having issue on my car?
Sep 9, 2008 at 2:15 AM
  • 110,248 POSTS
Hi:
If I understand you correctly, the engine RPM's go up but the car doesn't speed up with it. Is the transmission slipping? If so, there may be an internal transmission problem.
If you didn't get satisfaction from the dealer, I would have a transmission shop check it.
Let me know what you find out. I'm anxious to hear what trans shop has to say.
Oct 6, 2008 at 4:00 PM
