2003 Chrysler Town and Country Power steering
2003 CHRYSLER TOWN AND COUNTRY
71,000 MILES • 6 CYL • FWD • AUTOMATIC
GRASS18
My 2003 Chrysler T&C van will make a sound when turning like it is low on power steering fluid. The fluid level is full. It makes the sound only occasionally. Could the power steering pump be going out? It has 71,000 miles on it.
Nov 24, 2008 at 1:07 PM
  • 110,244 POSTS
HI:
It is unusual for a pump to go bad at such a low mileage, but it does happen. Have a mechanic check the rack and pinion for problems.
Let me know what you find.
Dec 1, 2008 at 8:37 AM
MJ22
Go autoparts store and buy ATF+4... very important +4. I had a major whine from my power steering pump. I sucked out as much of the fluid as possible from the reservoir, filled it back up with ATF+4, and whine went away almost immediately. You might have to repeat this process, or drain the pump completely to replace all the fluid with ATF+4. But this was an easy quick fix to my problem.
Mark
Jan 22, 2011 at 7:30 PM
