2002 Chrysler Town and Country RH Turn Signals Quit
2002 CHRYSLER TOWN AND COUNTRY
CJS45LJ
  • 5 POSTS
Electrical problem
2002 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic
The RH (front & back) turn signals quit working on my 2002 Town & Country. You can hear a flasher clicking in the dash when you turn on the RH signal and the indicator in the dash flashes at the normal speed but the front and rear turn signals do not light up. I checked the bulbs and they are good and I also replaced the turn signal switch in the colum but that didn't fix it either. Do you know where I can get a wiring diagram or even better what is causing this problem?
Thanks,
Cliff
Sep 19, 2010 at 5:45 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Does tail light come on ? if no check fuse #3 in Intelegent power module engine compartment. if yes maybe right turn signal relay inside left rear quater panel.
Let me know
Thanks for donate
Sep 19, 2010 at 6:18 AM
CJS45LJ
  • 5 POSTS
Thanks! I'm pretty sure I checked that fuse a couple of days ago and I have not been able to find the relay panel you spoke of. Is it behind the side wall or outside the passenger compartment?
Sep 19, 2010 at 6:39 AM
CJS45LJ
  • 5 POSTS
Yes the tail light comes on. I signed up for maintenance manuals and the wiring diagram shows a Body Control Module between the turn signal switch and the turn signal bulb. does this mean that there is no relay and that the Body Control Module could be bad?
Sep 19, 2010 at 6:56 AM
DOCFIXIT
  • 18,828 POSTS
That is a strong possibility the relays are behind left rear panel need to remove to gaun access. if relay coil is faulty then right side would not work. The fact that light on dash blinks means BCM is working
Sep 19, 2010 at 7:46 AM
CJS45LJ
  • 5 POSTS
All fuses are good and I removed the whole left rear quater panel on the left side and there are no relays what so ever back there. I have 12 volts all the time (turn signal on or off) at the right rear turn signal lamp white/brown and a good ground on the black wire. The left turn signal operates fine and has no voltage with the turn signal off. This sounds to me like the Body Control Module is bad since that is the only thing the wiring diagram shows up stream of the bulb. Would you agree?
Sep 19, 2010 at 9:22 AM
DOCFIXIT
  • 18,828 POSTS
Left and right of a vehicle is from drivers seat the white/brown is for left side tail. Pull park relay from Intelligent module does 12 V go to zero?
Sep 20, 2010 at 6:01 AM
CJS45LJ
  • 5 POSTS
I think you are looking at the wiring for the front turn signal and not the rear. I am using the diagram on eautorepair.net and it matches the rear wire colors for an 02 Town & Country. White and brown are for the front left and right rear turn signals. Any way I did what you said and the 12v stays there when I remove the Park Lamp Relay.
Sep 20, 2010 at 3:30 PM
DOCFIXIT
  • 18,828 POSTS
First post stated Right front and rear turn signals not work right? did you find relays? is there a trailer tow plug ? With voltage on wht/brn light should be on all the time on right front voltage on wht/tan?
Sep 22, 2010 at 3:17 AM
