2002 Chrysler Town and Country : may be transmission?
2002 CHRYSLER TOWN AND COUNTRY
104,570 MILES • 6 CYL • 4WD • AUTOMATIC
ALSTAR
when my car speed reach about 10 miles from start or after stop, I feel little jerking every time (it's been a week)
Like when you switch a gear in manual transmission car, your body shift to forward slightly.
I thought that was because road was bumpy, but it is not.
I checked transmission fluid, it is in max.
I'm not sure if it might have transmission problem, may be in the future? or something else?
Another thing is... I add CAM2 ATF D/M transmission fluid, I found out that I should have added ATF 4 only for this car. I added little abou 1/3 container..about a 6 weeks ago.. someone in the gas station said "it's ok. :("
I am out of town(VA) now and be back to my state(Illinois) in 2 weeks. I have to drive back...
Do I need to do anything right away? Thanks
Jul 18, 2009 at 6:11 AM
BMRFIXIT
  • 19,053 POSTS
What you add for fluid should be OK
not much to make any diff.
I do not suspect any harm done
the feeling is it at slowing down
check axles and mounts 1st
any check engine light on !
check idle if higher than normal
was the battery disconnected !
will do it have to run relearn shift
do a code check
Jul 18, 2009 at 4:36 PM
