2001 Chrysler Town and Country parking brakes
114,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAH1914
how to replace parking brakes pads
Apr 10, 2009 at 2:29 PM
CARADIODOC
  • 34,400 POSTS
Best left to a professional.
Do you have rear disc or drum brakes? What makes you think there's a problem with the parking brake?
Apr 11, 2009 at 6:27 PM
RAH1914
I have disk brakes with parking brake inside.
Last week, when pushing parking brake I heard a bizarre sound (crackeling) and after releasing the brakes, the ABS light turn on and I have an intermitent noise while driving.
Apr 12, 2009 at 1:10 AM
CARADIODOC
  • 34,400 POSTS
I would suspect you don't need new parking brake shoes. They usually last the life of the car unless the linings rust off.
If a cable is sticking, the shoes might not be fully retracted. You could be hearing them contact the rotating drum. If the red "Brake" light is on while moving, the anti-lock system will be disabled and the yellow warning light will be turned on.
There's a toothed tone ring and a sensor by each rear wheel, but my guess is the parking brake did not damage any ABS parts.
caradiodoc
Apr 12, 2009 at 8:10 PM
