In the last 2 weeks, my air vents have been giving off a coppery smell whether I'm running the AC or just fresh air. Doesn't seem to smell when the heat is on. It's strong when I first start the van and will lessen after a couple minutes, but you can still smell it. How can I get rid of it? I've been told there may be a HEPA type filter and changing it may correct the smell.
Know I live in FL and just went through Hurricane Faye (20+ inches of water on the roads).
As for the definition of "coppery smell" - the best way I can explain it is the taste you have if you touch the top of a battery with your tongue.
Sep 24, 2008 at 11:41 AM
